Window problem
Shinigami2x4
07-15-2004, 10:46 PM
I haveing a window problem on my 2000 camaro, It hasnt been going down , i mean it will but stop, then if i wait for a moment or two, it will go down a little more...and so forth ect. but the length it went down gotton shorter by the day...so any ideas...could it be the ground or the motor?
KaotiKCamaro5
07-15-2004, 10:48 PM
window motor.. new one on ebay will run ya pry 30 bucks at the most..
Shinigami2x4
07-15-2004, 10:53 PM
how much at an auto part store, and could you explain the steps into replace one...i know im not to...smart should i say
DaMoNe6969
07-15-2004, 11:52 PM
cant help ya out on how.. Never done it.. But im with Kaotic, sounds like your window motor is on its way out..
Just to be sure, you could check the harness and wiring at the motor, make sure its clean and good condition.. But 99% chance your motor is gone..
Chevyracincamaro
07-16-2004, 09:28 AM
your gonna have to take the rear-view mirror off and the outter door panel off. from what i hear it just bolts off. you get to the motor from the outside. ive never done it but thats what guys here have said...
sykotic1
07-16-2004, 11:48 AM
i dont know how it goes for the newer camaros but on mine i had to take the inside panel off. dealership wanted close to $300 to replace the motor, as they have to diagnose the problem themselves before they do any work, but still it was ridiculous. im not gonna say it was an easy task but it wasnt the hardest thing ive ever done either, might as well save the money and do it yourself. if the windows and motor are anything similar to a third gen i would make sure you have a good clamp to hold the window up and other basic tools should get you by.
Chevyracincamaro
07-16-2004, 12:15 PM
well yeah, sorry i thought it was understood that you would have to take out the door trim...
CamarosRsweet94
07-16-2004, 12:16 PM
Go to a parts store and get either a Haynes or a Chilton Manual, they have pretty decent step by step instructions in them, should help you out a lot.
Chevyracincamaro
07-16-2004, 12:17 PM
haynes doesnt have anything about the window motor and chilton barely touches on it, if at all...
CamarosRsweet94
07-16-2004, 12:18 PM
Well, the chilton helped me out a lot, it's better than guessing
Chevyracincamaro
07-16-2004, 12:20 PM
true, i actually dont remember what the chilton said about the motor. i threw mine away awhile ago...
89IROC&RS
07-16-2004, 05:07 PM
um... dont take off the sideview mirror, and dont take off the outter door skin, youd have to cut it off and weld it back on. all you need to do is remove the inner door trim, and drill out the rivits holding the motor in place, take it out, put the new one in, and rivit it back in place. granted a much simplified version of the steps, but thats pretty much it. do a search of the forum on this topic, someone posted a link to a website with pretty step by step instructions.
Chevyracincamaro
07-16-2004, 10:50 PM
and there's proof that not all the stuff you read on a forum is the best advice. blasted eyes, always gotta be readin stuff...
Shinigami2x4
07-16-2004, 11:37 PM
It shows that some advice ant the best advice, but advice all together, thank you for your input guys...it reallly bugs me since i have to use my p. side window to get air circ. ..also it looks weird if you know what i mean...Monday!!...is when my car gets a new rack and pinion...so it can finially be a quiet car...Expect for the motor and so forth disrupting the tranquiliaty
