Gear Grinding
vietxxxtasy
07-13-2004, 06:53 PM
I have a honda prelude '98 automatic transmission which has sport shifting. I lended my car to a friend of mind which is a rough driver, when i went to jail for about a month. When i came out i drove the car and everytime it goes from the first to the second gear the gears seem to be grinding. I was able to drive the car to and from work everyday. Pounding at first gear and when it automatically shifts to second gear i would let go of the gas so it would shift smoothly and driving to 3rd and 4th isn't a problem. Well i happen to lend the car to my friend once again and he took it too the mall. I guess he pounded it when the gears where grinding and every single one of my gears seem to be grinding and loose even the reverse. Now when i go to drive or reverse the car just sits there. I have to feather the gas to about 3000rpm before the car starts to move. Can someone tell me what i can do to get my car fixed and how much would it cost? Thanks
civickiller
07-13-2004, 07:01 PM
did you check the tranny fluid level ? try check it and maybe even change it and see if it helps
SiGNAL748
07-13-2004, 07:53 PM
does it grind when you're not using the sport shift?
vietxxxtasy
07-14-2004, 01:04 AM
yeh the gear grinds regardless even without sportshifting.
RPMtuner
07-20-2004, 01:28 AM
new tranny
vietxxxtasy
07-20-2004, 01:44 PM
how much would a trany cost on a honda prelude 98. im very low on cash so yeh.
