Turn Signals
dljohnson69
07-07-2004, 06:55 PM
Got a 90 LX that turn signals suddenly stopped working on. They are on a fuse and other things work on that circuits and nothing appears to be blown . Ideas?
StillGoin5.0
07-07-2004, 07:02 PM
when u turn on ur signals do u hear the relay clicking under your steering column? if not its probably the relay
dljohnson69
07-07-2004, 07:16 PM
No I do not hear them at all. Where would the relay you are referring to be located?
Thanks
StillGoin5.0
07-07-2004, 08:48 PM
it should be behind the panel just below the steering column about where your right knee cap. its easier to see if u take it off. its got a 3 wire plug into a small plastic or metal canister-shaped piece.(turn signal flasher) try and change that its cheep and probably the cause of them not working
dljohnson69
07-08-2004, 09:33 PM
Finally found this. It was on the passenger side. Maybe someone moved it when I put in a stereo or something. I had the whole dash ripped out before I found it. Kinda behind the radio. Just for future readers......
