power
91civic69
07-07-2004, 04:31 PM
everytime i want to use my breakes, signals, emergency, my stereo loses power it basiclly turns off i have check the entired car for a sort but i cant find it so if anyone has any idea please let me know
amitykamity
07-07-2004, 04:49 PM
I'm having a problem like that, my stereo main screen wont light up when I'm driving. Sometimes it will when I'm not, its all intermittent. I've checked all the wiring, and it seems ok. I've been told it could be the fuses or the battery, not sure if this helps at all.
Deze4gHatch
07-07-2004, 05:47 PM
I had the same problem, i thought it might have been the alternator, so i replaced it. It ended up that one of the cells in the battery was dead, so i replaced it, and it worked fine.
mattio781
07-08-2004, 12:51 AM
also check the ground cable or bolts on the frame near the headlights, not sure what there called, had the same thing happen on my 89 std, hit the breaks radio would freak out lights go dim check engine light come on, sucked ass
travagliante
07-08-2004, 01:42 AM
most likely your negative ground cable is loose and not tottaly connected.It happened to me when i moved my battery to the back of my car. If its not firmly attached to the frame it will almost short and cause the lights to get really dim, radio to reset, etc.
pauls81sc
07-08-2004, 07:00 PM
2 things to try:
First, check the condition of your ground cable. Corrosion = bad contact / intermittent contact. Try cleaning the cable connector and mating surfaces with an aerosol electrical cleaner (costs about $1.99)
Second, look for loose connections. I had an intermittent starter problem that my mechanic couldnt figure out. Turned out the previous owner did crappy job installing the alarm. I replaced a few wire connectors and problem went away. With the radio on, wiggle the wires and see if the stereo cuts out. Also if you feel any wires that are warm to the touch, that's probably where the problem is.
Good luck
Good luck
