setting the timing
beatruit
07-07-2004, 08:59 AM
I am having problems setting the timing after replacing the sprockets and chain? any hints on lining up the links correctly
JDPascal
07-09-2004, 12:44 AM
There should be a mark on each of the gears. when the gears are installed, the marks should be clossest to eachother and lined up inline with the center of the crankshaft and timing shaft.
good luck
JD
good luck
JD
JeEpBoY95
07-25-2004, 11:18 PM
you will probably have to turn the cranksaft and camshaft with the gears on but without the chain to get the dots to line up
