How to replace brake pads on a Protege 5
chuck b
07-06-2004, 09:26 AM
I'm not seeing the obvious, I'm sure. I do not see how to remove the pads.
Thanks!
Thanks!
mx3man
07-06-2004, 11:44 AM
you have to remove the calipers... un bolt the caliper from the back and the caliper should slide off. Then you can pull out the pads.
chuck b
07-10-2004, 07:39 PM
Thanks, I sort of thought that was the case.
