Where ar door switches?
mjolensk
07-03-2004, 07:31 PM
The Door Ajar light on my 2000 Explorer XLT stays on. I've slammed all the doors, but it stays on. Suspect it is the tail gate. I don't see any switches! Where are the door closed & tail gate closed sensors located? How do you adjust them?
XLT03
07-04-2004, 01:36 AM
The switches are part of your door latches. Spray WD40 into the latches and open and close the doors 5-6 times and it'll lube/clean the switches. Your offending switch is most likely the driver's door, it usually is.
robert J
07-27-2004, 07:50 PM
I have the same problem on a 99. I suspect my left rear door. I will try spraying the door latch in the morning. Thanks alot-Rob
