mysterious screetching noise help!!!
osok_deadeye_21
07-03-2004, 04:12 AM
When I accelerate fast my car makes a loud screetching noise. What could this be? Can someone please help me with this? I just replaced my transmission so I hope its not that. I thought it might be my timing belt or some other belt.
osok_deadeye_21
osok_deadeye_21
youngmanvr4
07-03-2004, 10:34 AM
I have the same thing with my car. It only does it at 5500-6000 rpm tho. But i'm pretty sure its my timing belt slipping.
Zero8985
07-03-2004, 02:18 PM
It might just be a serpentine belt that needs tightening.
osok_deadeye_21
07-03-2004, 02:20 PM
so it cant be my tranny? and can you tell me how i can know for sure what it is?
osok_deadeye_21
osok_deadeye_21
Igovert500
07-03-2004, 06:41 PM
I'm wondering the same thing, I get a screetching, almost metal on metal noise, almost like you are moving a steel cabinet across a floor and it is screeching. It happens under hard acceleration, usually in 4th, but sometimes in 2nd and 3rd. Thanks
osok_deadeye_21
07-04-2004, 02:38 AM
so no one knows how to tell what it is for sure? Will I have to go to a mechanic to get it checked out? How much do timing belts cost with labor usually?
osok_deadeye_21
osok_deadeye_21
Igovert500
07-14-2004, 03:53 PM
OK, well I'm thinking this is my problem:
http://www.3si.org/forum/showthread.php?t=222974&page=1&pp=10
Leaky BOV
Leaky BOV
93_R/T_TT_Stealth
07-14-2004, 04:28 PM
timing belts are from 180-200 dollars for the stock belt - an while your at it u might as well change the water pump while ya have half the side apart - cause the water pump can be a pain in the ass to change - so if you havnt the seal changed or the pump might as well do it if u plan on keepin the car - its on the drives side behind the timing belt ..... good luck
osok_deadeye_21
07-14-2004, 08:16 PM
what does bov mean? I want to know since I am selling my car and when someone drives it they might hear that sqeeling noise and think its something bigger then it really is.
John Pannebaker
07-14-2004, 08:33 PM
Hope it's your serpentine belt (fan belt). Go buy some belt dressing, don't like the stuff personally, but if it isolates the prob. spray it on sparingly. If the prob. goes away you should tighten up the belts anyway but comes back latter, don't keep using the dressing, time to install a new belt
osok_deadeye_21
07-14-2004, 09:00 PM
so what do they mean by a leaky bov? How can you tell what it really is instead of having to spend alot of money to find out?
Zero8985
07-14-2004, 09:53 PM
Bov is a blow off valve, that is probably not where your problem lies. I honestly don't mean to sound like an asshole when i say this (because i already know it's going to sound like that), but i'm going to go ahead and say it. To find out what your problem really is, you either have to:
1.) Check it out yourself.
2.) Give us more information to work with.
3.) Take it somewhere and spend some money to figure it out.
Saying you have a loud screeching noise under hard acceleration isn't going to get you an exact answer. My suggestion is you have your serpentine belts checked, because i had that same problem before.
John Pannebaker
07-14-2004, 11:23 PM
If you don't have turbo's, and you don't! you will not have a Bov. Go to any auto parts or service station and spray on some dressing and then get back to us.
osok_deadeye_21
07-14-2004, 11:38 PM
Ok I will try the dressing idea and if that doesnt work oh well im selling it anyways.
