can aftermarket intake cause problems?
c kim
07-01-2004, 09:35 PM
Can an aftermarket intake cause the factory exhaust to blow?
The reason I am asking is that my buddy got an aem sri for his civic and a little while later, he blew a hole in his stock exhaust. The car has low miles so I can only point the problem towards the intake. Is it the intake's fault?
emerge
07-01-2004, 10:02 PM
Intakes only make your car sound better. SRI's especially. IF it was the intake, his mass airflow sensor would've produced a check engine light.
Ricochet
07-02-2004, 09:10 AM
How do you blow a hole in the exhaust..
Anyways, no, there is absolutely no way a shiney little intake on a Civic will cause that.
Kafziel
07-02-2004, 09:30 AM
Only way an aftermarket intake will cause problems is if you get too much water in it. But that will screw up your engine, not the exhaust. Probably just a coincidence.
