Ka turbo Compression?
bestdrifter
06-30-2004, 11:27 PM
When you turbo a ka wont the compression be bad because the Ka was designed to be N/A not turbo?
bestdrifter
07-01-2004, 12:38 AM
I mean on a n/a engine it is high compression but on a turbo engine it is low due to the turbo...?
logik23
07-01-2004, 12:47 AM
When they turbo the KA, people usually get a thicker head gasket to lower compression. Or get turbo pistons which will also lower compression, but are a little more complicated.
SR240Z
07-01-2004, 12:53 AM
for high power people get new forged pistons with lower compression and a metal headgasket to be safe
bestdrifter
07-01-2004, 02:24 AM
Thanks for the info, guys
mynismo
07-01-2004, 08:32 AM
i think ka compression is 9.5:1. you get more power but are closer to detonation.
Jackalope17
07-01-2004, 01:16 PM
I had heard that the 89-91 compression was 9.5, but the 92 up engine had 8.6:1?
also that the 92 was better for boost because of a different cam profile...can anyone confirm/deny any of this?
turbo2nr
07-01-2004, 01:19 PM
i believe in 92 the ka24de had a dohc motor and the 89-91 had a soch cam desing..
1
1
logik23
07-01-2004, 01:41 PM
89-90 Sohc
91-98 Dohc
91-98 Dohc
