USDM b16 parts
RedRex16
06-30-2004, 11:01 PM
This has probobly been asked before but, ive tried searching and found nothing. My question is, do parts off the usdm b16a fit/work on the jdm b16? parts like a header, cams, cam gears? thanks
Kunundrum
06-30-2004, 11:13 PM
yes
travagliante
07-01-2004, 12:54 AM
Yes but when it comes to like distributors, clutches and others they dont work... Clutch must be off a 90-91 teg(if cable tranny) distributors(usdm doesnt have a obd0 b16a), but parts like cams cam gears, valve, header, pistons, etc. Work all fine.
Hybrid1990crx
07-01-2004, 03:09 PM
Just to clear things up for you just incase you don't know. The reason you can't use the dizzy from USDM b16's is because they are obd2 in the newer civics. Not sure about the del sols, think they may be obd1. JDM b16's are obd0.
Hotcivic1115
07-18-2004, 02:12 PM
I was wondering the same thing. I don't know which usdm car is close to the JDM B16A1. will usdm honda parts like an air filter fit my B16? or do I need integra parts. and I want to buy slotted rotors for the new axles that came with the swap, do I buy integra rotors? if so, what year? Which car is the most closely related to the JDM b16?
thanks a bunch guys
viper_2_4
07-18-2004, 03:34 PM
thanks a bunch guys
the 99-00 Si (or SiR up here in canada) had the obd2 b16 in it, the Del Sol VTEC had a b16 in it also.....
YZ125rider21
07-18-2004, 04:39 PM
by the same rotors which year your car was made only thing you did diff was get new axles...which all plug and play into your rotors bro...all i can help you out with here
mellowboy
In simple terms...Everything will fit but the sensors and clutch.
Hotcivic1115
07-20-2004, 09:51 AM
thanks for the info. But, actually, the axles came with new spindles and hubs, so the rotors and calipers are much bigger than my stock 89 civic ones. I am also looking into buying new headers. but I'm not sure what car to buy them for. Does anyone know what kind of car the JDM B16a1 engines come out of??
thanks a huge bunch
mellowboy
07-20-2004, 01:18 PM
I'd get the jdm DC sports header. The best flowing header for that price range.
