Disengaging the Airbags
SideShow Sean
06-29-2004, 10:36 AM
I just bought a 97 wrangler and i am wondering where the disengage switch is for the airbags or if their even is one. I was looking at tuffy center consoles and i found one with a mount for the airbag switch which leads me to believe it would be somewhere near the shifter on the console i have now if their was one. If someone could help out this greenhorn it would be appreciated.
fredjacksonsan
06-29-2004, 03:14 PM
Check your owner's manual if you have one, the procedure is documented in there. You can either pull the fuse (located behind the glovebox) or disconnected something on the 100-way (or was it 50-way?) switch under the dash.
