auxilary valve???
blueboy450
06-26-2004, 10:15 AM
hhy everybody, i,ve post a thread juste before for my idle trrouble a i was doing some checking to find that my auxillary air valve has no power on is connection (no 12v like my injectors) when the ignition is a the ON position,,,do you think that can cause the engine run really bad when i starte it, he runs about 200 rpm, don't dies but not to far.
thank you guys
thank you guys
83-944
06-27-2004, 06:47 AM
Try plugging it before the valve. that wold tell you if the valve is stuck open.
the aux air valve was for the A/C so it should only come on when the compressor kicks in.
blueboy450
06-28-2004, 04:36 PM
Thank you mr 83-944, when you says to plug it before the valve, humm do you talk about the electric connection?? because there is an electrical connection like the injector, and i see a hose on the side of the valve.. excuse me to dont understand but i,m a bad mecanic :rolleyes: . have a nice day
83-944
06-29-2004, 12:08 PM
Take the hose off and plug the end of the hose.
