Security light is on and car will not start
goldielox
06-25-2004, 10:28 PM
I hit a pothole and the car stalled and I can not get it started. It seems like it is not getting gas. Anyone know how to fix that? :1zhelp:
goldielox
06-25-2004, 10:29 PM
can someone help me???
s_jo4
06-26-2004, 10:44 AM
could have knocked a connector or harness loose somewhere, but does the car try to turn over and start? model/year?
kilroypr
06-27-2004, 10:42 AM
Well something like that happend to my 94 Z34 and it was that the fuel pump harness had loose wires. FIrst of all if the car cranks check the fuel pressure at the injectors. If there is pressure then you should check that there is spark, but, in your case I bet you do not have fuel being delivered to the injectors. If the securoity light is on then there should be a fuse to disable it, but, it is supposed to disengage when the correct key is on the ignition and the car is cranked.
