b18c1 swap in 98 civic hatch
civichatchguy
06-25-2004, 01:52 AM
my questions are one. i can't find anyone that makes motor mounts for a b18c1 swap in a 98 civic hatch dx. will the stock ones work?? the second question is someone said i need new axels and then another person said i didn't does anyone know?? also if anyone knows where i can find an engine wiring harness let me know or if there is a way to convert my stock one to work then tell me how. thanks.
95TegSE
06-25-2004, 05:32 AM
Hasport doesn't seem to make the mounts you need but Avid does. http://www.avidracing.com/motormounts.html. You might need to use the b-series axles for this swap. As for the wiring harness, there are subharnesses made so you can use your stock harness, but the only ones I've seen are OBD1, and your car is OBD2, so that doesn't really help much, unless your b18 is OBD1 and you're planning on converting, but check hasport out for their harnesses.
salbaje
06-30-2004, 02:33 AM
hit me up i can get you mounts and harness salbaje@comcast.net
