idling rough
Mram76
06-24-2004, 02:38 PM
i have 99 rs ... it's idling rough on stop lights and drive fine when in motion. i can the plugs twice.. NGK and wire [factory] also i change the TPS and isc but i still idling rough.. can someone please help me.....also i notice when i start the car in the morning some white smoke come out of the exhaust...then after a while it goes away.........thnx please help............
ashah000
06-24-2004, 02:55 PM
What is rough about it.. too high/low, surging?
Mram76
06-24-2004, 06:19 PM
it stay normal but then drop to about 500 rpm..
ashah000
06-24-2004, 06:21 PM
Does it come right back up? So it acts like it is about to stall and then revs itself back up to idle.
Does it do this all the time or just when it is cold.
1stGenRocks
06-24-2004, 09:35 PM
what about is the ac on or off does it do something different with it on/off
metalhedskater
I have a similar problem....please see my thread about it...."UICP and BOV prob"
Mram76
06-25-2004, 07:14 AM
it's been do it for a two months now. the idling at the light it drop 500 rpm and stay until i drive... it happen everytime i idle at stop light. the car drive fine. however when the ac is on it stay normal...
yes it do feel like it's going to stall but don't.......thanks
Mram76
06-28-2004, 08:56 AM
my car is not turbo ... i have 99 rs . no UICP and BOV prob"
metalhedskater
06-28-2004, 10:16 AM
you have to set the idle speed connection....there is a screw by the throttle body that you turn....you need to grow the timing connection to your firewall and ground the diagnostic plug in the car on the drivers side....it wil be plug 10 and 4 i believe....the directions are kind of vague, but if you go to http://65.54.172.250/cgi-bin/linkrd?_lang=EN&lah=e5b6e148ead4393fc2d661c8648dd7fd&lat=1088435732&hm___action=http%3a%2f%2fmembers%2eshaw%2eca%2fcos tall%2f1000Q%2f its a little more clear, but if you try it and have success let me know because i did, but i obviously did something wrong...
momsbrownies
06-28-2004, 10:54 AM
my '97 gs idles rough but when i bought it i was told that it needed the motor mounts to be replaced...it's fine when you touch the gas
metalhedskater
06-28-2004, 11:12 AM
i dont think the motor mounts would affect the rpms if thats what your suggesting....but the motor mounts might affect the driving of your car and the noise of the motor from instability...my friends did that...
Mram76
06-28-2004, 01:00 PM
i change the front and rear motor mounts at the dealer. also there is no screw to turn the idle next or on the throttle... i change ISC and TPS but no help can he 02 sensor have any affect.....thnx...
metalhedskater
06-28-2004, 02:03 PM
yea there is a screw to change the idle....it has a black cap on it.....and its ON the throttle body....
spyderturbo007
06-28-2004, 02:10 PM
I thought only the 1g had the BISS?
metalhedskater
06-28-2004, 02:15 PM
no its definately on the second generations....im not sure if its on the n/t
HotCrew
06-28-2004, 08:31 PM
Could it be a vaccum problem?
1stGenRocks
06-28-2004, 08:35 PM
check all your electrical and vac lines/connectors actually make sure they are tight lots of times they look like they are but they're actually just barely loose but enough to make the connection leak
momsbrownies
06-29-2004, 07:39 AM
the engine doesn't really sound 'rough' it's just that the steering wheel and mirrors have a little vibration to them (until u touch the gas). i've got to put it in the shop for a check-up/tune-up (just got it), reverse lights, and inspection... so hopefully that will take care of it
Mram76
06-29-2004, 09:52 AM
there is no biss screw.. there is a screw but it round out i cannot turn it......
metalhedskater
06-29-2004, 11:45 AM
oh well that sux mram76. Maybe its just not applicable for non trubos..
metalhedskater
06-29-2004, 11:51 AM
my next guess would be the o2 sensor because of the white smoke...but that might just be condensation in the morning...if it doesnt persist i wouldnt worry about it....but check out this site and look around for the pics showing you where biss is. I dont understand how it could be on turbos and not on n/t....let us know how it goes! If that doesnt work and no one can figure out the problem....i think autozone does some free diagnostic tests instead of paying 100 @ the dealer
metalhedskater
06-29-2004, 11:52 AM
sorry here it is.... http://members.shaw.ca/costall/1000Q/
Mram76
06-29-2004, 02:06 PM
Thanks... I Chec To See If The A Vac Leak...i Sure The Biss Screw Is Shaved Off, So Can't Be Turn... That's Sux....if Not I Am Going To Autozone...
RiceRocket18
10-15-2004, 06:23 PM
most likely it's covered up by a black rounded seal.. you needa pop that off to see the actual screw.
gthompson97
11-23-2004, 04:24 PM
i know this thread's a few days old but i was just gonna add that my car did that too. i replaced my first o2 sensor and that helped but if your battery went dead for awhile or your computer had a power loss for a certain amount of time, it lost all memory for drivability conditions and therefore has to re-program itself.
