Advice On Head Removal
98GSX
06-23-2004, 03:02 PM
anyone have any? I am having trouble getting the intake off... there are those 4 bolts on the bottom and i cant reach them!!! what do i do!
nicerydez
06-23-2004, 04:55 PM
if your intake system is like mine when i did my head it is a 2 peice intake where you can seperate the top portion from the bottom portion. their should be 5 bolts under that piece where your throttle body connects to, i don't know what that thing is called?? it's that tube thing that air goes into and then splits into the 4 cylinders??? but if you can seperate that then the bottom portion come off real easy.. good luck
if yours isn't a 2 peice then i would get someone with rubber arms and small hands to do it because they must of had some of them around when they built those cars.... :iceslolan
98GSX
06-23-2004, 05:18 PM
hehehehhehehe good one
kjewer1
06-23-2004, 10:07 PM
I can usually reach them from the engine bay, using ratcheting box end wrenches (like Gear Wrenches). OTherwise, if I have the transfer case off (5 mionute job anyway) I can easily get to them from below.
boostdog
06-25-2004, 02:30 PM
u'll just have to grin and bear it..when i did my head swap they were a pain in the @ss to get to and put back on...u can do it though just be patient.
98GSX
06-25-2004, 02:48 PM
a 97 Tsi head will work on my 98 GSX right?
kjewer1
06-25-2004, 07:40 PM
No difference between 97 and 98 heads.
