'04 Steering wheel position (problem)?
CahariN
06-19-2004, 08:33 PM
Was wondering if this is a serious problem to rectify.
I just noticed that my '04 GP GTP's steering is a bit "off"
The steering wheel's full lock (left) will have the steering wheel at the 3 c'clock position, but then I have to full lock (right) it's between 1 and 2 o'clock position.
Anyone has any ideas why?
Thanks.
GTPCatz
06-20-2004, 10:33 PM
maybe you should draw a picture...im not understanding
CahariN
06-21-2004, 12:10 AM
Thanks for the reply,
Hmmm ok, the steering wheel is now refered to as SW.
When the SW is turned to the left as far as it will go, the SW points to the 9 o'clock position (Full lock left)
But when it is turned right as far as it will go, it points to 2 o'clock position.
Basically I believe whenever you turn your SW to the max limit, the final resting position should be mirror images of each other, but mine isn't.
x
o o b
a o o a1
o o
o
Ok... so let's say the above "image" is the SW. The max it will turn (left dir) is to position 1 (about 1.25 turns/revolutions) so that the "x" is facing "a". But when I turn it right (almost 1.25 turns), the "x" stops at position "b" when I think position "a1" would be wherer it should stop..
Sorry for the crap pic, I failed art class. Lol, I'm a cook, not a painter.
Thanks for your input.
CahariN
06-21-2004, 12:11 AM
Ok.. thatr pic didn;t turn out right.....
Bacicall, after 1.25 revolutions left, the top of my SW faces W, but when I turn it right, it does less than 1.25 revoultions (turns) and faces the NE. Makes sense? :P
GTPCatz
06-21-2004, 01:43 AM
Ok I understand...I will have to check on that
CahariN
06-21-2004, 05:01 PM
Thanks, appreciate you lending me some assistance :) Hope it's good news.
CahariN
06-21-2004, 09:18 PM
Just so you all know, I've decided to send the car into the dealership to see what's wrong (At 7am!!). Stay tuned for the update.... If I'm lucid enough to type it out :sleep:
CahariN
06-22-2004, 07:04 PM
Ok, sent the car in, and the dealer said that the steering is within specs. Any other 04 GP GTP owners can confirm that their steering wheels DO NOT lock at the opposite position when turned to the max?
Thanks
GTPCatz
06-22-2004, 07:36 PM
I have a 04 rental currently and I checked the steering and it does the same as yours
CahariN
06-22-2004, 07:48 PM
Ok thanks GTPCatz.... at least I know now :)
Why didn't you tell me before I sent my baby to the dealership? :P
GTPCatz
06-22-2004, 08:07 PM
I wasnt able to verify till this afternoon!
