Corner Head Lights
DiS
01-24-2002, 10:46 AM
Fellas. Im trying to change the light bulbs in Corner Head Lights and for now I have no idea how to do it. I was thinking to take the lights apart but have no idea how to do it either. I just want to change the stock light bulbs to Blue neon light bolbs. So if anyone knows how to change these Corner head lights please let me know ASAP. Thanks. :confused:
NJMAXSELTD
01-24-2002, 02:41 PM
You are refering to the side markers correct? If you reach down under the hood, in the corner of the inner fender right under the light. Look for the wires, follow them up to the bulb socket. It's very a very tight spot but you can get in there with your fingers to twist them out. Then change the bulb.
TIP - The bulbs that fit in those sockets can only go in one way do to the nibs on the bulb. If you file off the upper nib and put the bulb back in the socket turned 180 degrees you will light up the higher wattage filiment and the bulb will be 10X brighter.
PIAA 1157 Extream White bulbs work excellent in there. Make sure you light up higher wattage element though.
Mr Nismo
01-24-2002, 03:38 PM
Why not just take off the side marker and put the bulb in??
Ravq
01-24-2002, 07:48 PM
Are you talking about the clearance lights (next to the headlights) or the side marker lights located on the bumper? If it's the clearance light then all you have to do is unscrew the bulb holder from inside the hood. If it's the side marker light then you have to remove the lens as follows:http://www.seas.ucla.edu/~cheston/clears.html
DiS
01-24-2002, 11:57 PM
Yes. I'm talking about clearance lights (next to the headlights) Have to keep this name of lights in my mind :sun: Keep forgetting it. Anyways that's what I was looking for. I'm trying to change stock light bulbs to blue neon lights. BTW I want to change headlight bulbs too. So pro-ly will do that. Thanks fellas.:smoker2:
MegaMax
01-29-2002, 11:46 AM
http://www.custommaxima.com/Images/WindshieldWasher.gif
Dre's Corner (http://www.zupsbasement.com:880/corner.htm)
I have to look for a pic of my headlights when I have my Neon on... I have the Headlight Neon Kit in my headlights..
