need suggestion
LOKO706
06-17-2004, 08:42 PM
heyyy wassss uppp i need some suggestions should i put new rings and bored the motor and put bigger piston or put a turbo in it? i can do the pistons right now but the turbo it will be hard to find one around here
nissanfanatic
06-17-2004, 08:49 PM
Test the compression. If bad, change pistons and rings. If you get the block bored. Don't go very far. Like twenty over. Make sure you get the right sketch pattern on the walls for the rings you get. Turbo is a better plan if you want power. The pistons won't give you any usable power really unless you have bad compression now. You obviously have a computer, so you can find a turbo pretty easily if you look. www.ebaymotors.com , www.cheapturbo.com and www.atpturbo.com . Remember, KA-Ts have been known to go up to 400hp and 400tq on STOCK internals after 114,000 miles. Dont believe me, go to 240sxforums.com and look under KA24DET forums. Tell that to some of those guys.
