'89 with no spark,no fuel. turns over
public
06-17-2004, 12:28 AM
Heres the scoop. Mine is a '89 Cavi 2.0 4 cyl. I went to it move the other day. I turn the key, I can here the fuel pump as normal and the engine rotates. It does not start???? I check and find that I have no spark and the injector is not shooting fuel. I am getting no codes from th OBDI . I remove the injector and it is getting fuel. I have a few ideas but thought I would see what you guys have experienced. I am thinking ECM or Ignition Switch. Maybe a bad ground, but everything else works so might be local to the ECM. Any Ideas Welcome. Thanks.
Three_Fingers
06-19-2004, 07:43 AM
Check crank position sensor-it tells the coil when to fire.
public
06-19-2004, 03:45 PM
Yea, it don't have a crank position sensor but it does have a camshaft position sensor that does that. I was thinking that could be it but it is real hard to get to so I was hoping for anything else ha ha. Looks like I'm gonna be gettin dirty. Thanks
scutter
06-23-2004, 03:10 PM
try the ignition module mine did the same thing. Replaced the ignition module and fired right up.
public
06-23-2004, 05:18 PM
Thanks. That is my plan for tonight. I'll let ya know. I have a lifetime warranty on the one in there now so I can test this theory for free. I just wish they would put the thing somewhere accessable.
public
06-25-2004, 08:17 PM
Well the module tested good. and I stand corrected. It is called a Crank Position Sensor. Now I just have to find it. The Haynes manual says on the back of the motor. I don't see it. Down low I suppose. Under it I go..
