Changing a 98 Park Avenue Coolant level sensor
roywagner
06-16-2004, 06:08 PM
Changing a 98 Park Avenue Coolant level sensor- is it easy? Cost ?
My dash is showing every couple of minutes Coolant level low.
The system was flushed by the dealer and they say that everything is OK.
Level is not low.
Another mechanic said that he thinks that the sensor is bad.
Can I change the sensor easily, or is it inside or at the bottom of the radiator?
Also, the PA is Supercharged and the head of the supercharger was changed about 10000 miles ago.
I saw posting that leaking O rings can cause low level of coolant, but as I said the level is OK.
Thank you
Roy Wagner
