Fuel pump won't shut off
19k40rocky
06-15-2004, 11:23 PM
The fuel pump on my 89 grand prix keeps running after you shut the car off. I finally disconnnected the battery. I noticed the guages didn't zero out either now. Anyone got any ideas what is going on with this thing? All help and ideas would be much appreciated.
AKWE-gt
06-16-2004, 02:26 AM
should check your fuel pump relay could be stuck.
michelq
06-16-2004, 05:00 AM
check oil sending unit and wires
19k40rocky
06-16-2004, 08:17 PM
What do I need to be looking for when checking the oil sender and fuel pump relay? I hooked the battery back up tonight and now no fuel pump noises and guages did what they were suppose to do, but who knows when it might do this again? I turned the key to start it up and the fuel pump kicked in and pressured up (that whirring sound you hear for a few seconds) and kicked out like it is suppose to.
Dr.Rockin
06-17-2004, 08:01 PM
I have a 1990 GP and have the same problems, It doesnt happen all the time, but it seems to run for quite awhile after I shut off the car. But eventually it does shut off. I have noticed that the oil sending unit is now leaking alot of oil. Think replacing the sending unit might fix the fuel problem??
19k40rocky
06-17-2004, 11:31 PM
curiosity is killing me. how are the two things related? does it somehow backfeed current through that circuit?
michelq
06-18-2004, 06:46 AM
curiosity is killing me. how are the two things related? does it somehow backfeed current through that circuit?THE oil sending unit act like inertia sw .it is commen to go bad ,fuel pump wires runing throu the oil sending unit.
19k40rocky
06-19-2004, 11:10 PM
I understand now. that helps a bunch! thanks for the info!
