engine blowing up question
zerosilver19
06-15-2004, 06:54 PM
I drive a 1999 sohc vtec ex civic and it only has 50k miles on it and iw as racing a car just for fun down route 79 in pa and well the engine blew i was wondering what could of caused this i shifted ever gear at 6600 rpms oil got changed every 3-4 months. what happed was 2 rods blew threw the side of the block. only after maket part i had was a cold air intake from aem and exhaust custom built. I planned on replacing it with a jdm sir2 motor when i get back from basic and school from the air force in october and i leave this monday so not having a car isnt really a problem, i was just wondering what could of caused this. Thanks
rubix777
06-15-2004, 07:46 PM
well, if you redlined every gear for all those 50k miles of course it's going to break.
Beyond Imagination
06-15-2004, 09:00 PM
i think your engine blew cuz you were street racing.
zerosilver19
06-16-2004, 12:34 AM
i've always street raced a couple times a month, and redline on the ex is 7200 so i shifted under redline and the peak power is made at 6500 rpms i think just up till a month ago i started shifting at 6500rpms around there before that i shifted at 5500rpms.
zerosilver19
06-16-2004, 12:35 AM
also i only had the car for 20,000 miles i bought it with about 30k on it and drove it safely about 4500-5500 rpms daily.
GFresh
06-16-2004, 12:47 AM
Because it's a civic.
udelblue
06-16-2004, 07:25 AM
since you have alot of downtime i recommend swapping for a b18c you can rev the hell out of that if you like. much less of a chance of it breaking. plus it will give you the power that is obvious that you desire
movingshadow
06-16-2004, 03:10 PM
Sounsd like you were high up in the rpms in one gear (im guessing 4th?) Maybe third, and when you shifted you got a bit of a slingshot effect and it probably went dry trying to crank into the next gear so fast that it just crashed you. The red line is there for a for a reason.
zerosilver19
06-16-2004, 05:03 PM
i am swapping a b16a2 in it so i can redline the hell out of it and building that thanks...
JimCRX
06-25-2004, 04:43 PM
The Higher the RPMS = More Stress on the Engine
You can pretty much solve the rest.
GWInquisitor14
06-25-2004, 08:02 PM
You probably spun a rod to crank bearing from the high revs. It is pretty un common to see a bearing spun that soon in the engine life.
ciVTEC94
06-25-2004, 10:44 PM
maybe you lofted the valves, too much fuel got in and wasnt burned right away, and all at once too much was ignited, causing blowback
chechin
06-27-2004, 07:25 PM
the civic sohc engines are too bad for racing purposes, I also blewed a D16Y5, now I have a B16A2 and I rev it to 7,800-8,000rpm every day, and nothing is happened yet...hehe.
