97 izuzu rodeo no start no run
Jstorm22
06-15-2004, 03:12 PM
trying to repair 97 rodeo no power to fuel pump, no spark, everthing else in the truck works fine all fuses and relays are fine. so far im looking at either the body control module or crank sensor any body else have any ideas. 3.2 liter.
danforth45
06-15-2004, 10:50 PM
so you are getting power to everything else? bang on the fuel pump, sometimes if they are old they will stick and if you bang on them they will work for a little while.
hope this helps
Jstorm22
06-16-2004, 08:58 AM
well you see the fuel pump works fine if i supply it with power at its fuse it has no juice at the fuse any time, with ign. on, cranking the motor doesnt matter just no juice everthing else has power in the fuse box but the pump but i also have no sparkage im just not that familair with newer electronic cars im a diesel mechanic by trade and build drag cars for fun but this stuff really makes my brain hurt so thats why i came here for help so thank you for your feedback every reply is greatly appreciated.
danforth45
06-16-2004, 06:57 PM
it could have something to do with your ignition switch because that is what turns on the fuel pump and spark when you turn your key on. thats my best guess.
hope this helps
Jstorm22
06-21-2004, 02:01 PM
well found something, pcm is getting no power from relay. there is juice coming out of the fuse panel but it is not making it to the puter. so time to trace this down i guess.
2eyefishclaw
06-21-2004, 10:32 PM
check the ground on the side of the alt. bracket if its loose it will cause this
Jstorm22
06-29-2004, 09:39 AM
nope thats tight thanks though
i got it runnin bye running a new wire from the relay to the pcm. now its running poorly and check engine lights on so im kinda back were i started . atleast i can move it around now lol.
danforth45
06-30-2004, 05:38 PM
now take it to auto zone and have them run a diagnostic on the ecu. they do it for free, that will tell you what is causing the check engine light
