02 Grand Am GT tranny problems....Help
odb93
06-10-2004, 09:29 PM
V-6 engine.
My friends car when shifting from 1 to 2 with higher rpm the car feels like it is spinning the tires. Even though this is on dry blacktop. I know the tires are not breaking loose.
Could this be a tranny/engine mount??
Has anyone else seen this???
I searched, but was unable to find anything.
Help me Rhonda!!!!
Help me Rhonda!!!!
Pvt_Murphy
06-15-2004, 07:51 PM
the stock goodyears aint that lovely in terms of traction :( .
take another car and your freinds and see if you can actually see anything out of line when he shifts into 2nd in the higher rpm.
achievasc92
06-15-2004, 11:57 PM
it may be slightly breaking loose between shifts, my 3100 with chirp into 2nd when its cool out and it will spin like crazy when the ground is wet.
odb93
06-16-2004, 06:09 AM
The thing about it is the tires are not making any noise. No chirping or spinning noise what so ever.
I thought it might be a mount of sometype causing the problem.
achievasc92
06-16-2004, 10:01 AM
maybe, its hard to diagnos without driving the car. BUt a bad mount will usually end up killing power on takeoff and shifts because the engine will move excessively therefore wasting power.
odb93
06-16-2004, 10:19 AM
I need to pop the hood the next time I am around the car and see if the motor is moving either in reverse or forward when you give it gas. That should elminate the mount question.
I just wondered if anyone had experienced the same issue before.
