Acceleration and shaking
Josh278_2000
06-03-2004, 08:02 AM
I have a 94 grand am V6 and lately the acceleration has gone way down. I was hoping that someone could shine some light on why. I think that it is the spark plugs but I am not sure. Also my car was shaking very rapidly and now it is only shaking a little bit but it seems that the shaking has worsened. At 50 mph is when the shaking starts and when i let off of the gas it will stop. Also my vehicles top speed has gone down from 110 mph to 85 mph. I was hoping that someone could help me out and shine some light on my problems. thank you.
fluffybunny
06-03-2004, 01:02 PM
ya know if vibration occurs when traveling especially at higher speeds 50+ id have to say it was something either in the suspension or movement related......ball joints, steering tie rod ends, axels....etc. i would think that if the plugs were causing a miss you would feel it at idle. id suggest getting under the car and looking for something that seems out of place or damaged/broken. can you tell if its from the front or back? left or right side? could be a tire... just a matter of weeding things out.
Josh278_2000
06-03-2004, 01:47 PM
It is definetly in the back. it seems to be centered. I dont think that it is a tire because i recently put new front tires on it. I also do feel a miss when I am at idle so it could be the spark plugs so i will try that and i will also look into those other things.
Do you think that it could be a motor mount? please get back with me on this and thank you for your suggestions.
fluffybunny
06-03-2004, 06:41 PM
could be a motor mount, but i would think that would be visually obvious. as far as the plugs, i dont think there would be a upper rpm range that it would affect. it would probably be present through the rpm's.
Markgase2000
06-04-2004, 01:53 AM
Could be dirt in the wheels
Josh278_2000
06-04-2004, 10:01 AM
When i am in park and put the car in drive I hold the brake and hit the gas and you can look at the engine and see the whole engine lift up. suggestions?
Markgase2000
06-04-2004, 10:15 AM
When the car is in gear it will lift the engine when giving gas and applying the brake , it supposed to do that , its the engines mounts that allow some movement of the engine. But dont do that , you have a fwd only one of those pedals are meant to be pressed at a time and could damage your transaxle.
fluffybunny
06-04-2004, 03:06 PM
have you had your rear tires balanced? the weights sometimes fall off. just something to think about.
Josh278_2000
06-07-2004, 07:39 AM
yes tires were balanced do you think i might need a front end alignment
jeter1955
06-07-2004, 07:55 AM
well if you can feel it at idle then its not a suspension problem.. as soon as mine hit 4th gear at 50mph and trying to hold steady it would shake like all hell.. i found a stripped out spark plug in the back.. you might want to make sure all of your connections are tight and trouble free.
Josh278_2000
06-07-2004, 08:29 AM
I just changed the spark plugs and wires so I do not think that is the problem but thank you
Markgase2000
06-07-2004, 09:23 AM
Could be toe or camber/castor if theres nothin else wrong with it.
