HELP! changing the front rotors on a 2000 rodeo
aaronw425
06-01-2004, 05:55 PM
i can not get the rotor seperated from the part with the lug bolts. does this need to be pressed off? any help will be greatly appretiated
Dober89
06-01-2004, 10:02 PM
Are you sure that the rotors and bolts are not one unit?? I have not had my brakes apart yet so I dont know for sure but my other car has wheel studs that are part of the rotor.
2eyefishclaw
06-01-2004, 10:39 PM
once yor tire has been removed the brake caliper must be removed then the rotor should just about fall off if not place a 2x4 against the rotor and pound the crap out of the 2x4 untill the rotor comes sounds like its just a bit rusted
rodeo02
06-02-2004, 04:54 AM
You need to take the hub apart to get the front rotors off the spindles on pre 2002 rodeos. Check here: http://www.planetisuzoo.com/articles.htm/56
G/luck
Joel
