brake disc questions
c32b1 NSX
05-21-2004, 10:53 PM
i was just wondering how it would help if a disc/rotor is vented, slotted, or drilled or all of them. thanks
hemip
05-22-2004, 03:50 AM
Wented rotors gives better cooling of the disc. But within the same size it contains less iron which means it cant absorb as much heat. A solid disc is more stable and may be able to withstand a longer single braking distance without overheating.
Slotted rotors keeps the pads cleaner. Drilled rotors are not very good as they are prone to crackings.
They are mostley used for looks...
Goran Malmberg
Moppie
05-22-2004, 05:49 AM
READ THIS: http://www.automotiveforums.com/vbulletin/showthread.php?t=222611
Its considered good forum etiqute to check the top of a forum for stickied posts, then to read them and make use of the information they contain.
Debates and discussions on brake discs have been covered several times over in these forums, and even a simple search should furnish you with any information you need.
After searching for, and reading them, any further technical questions you have may be asked in a new thread. Making sure of course the information you seek has not already been covered in an existing thread.
