keyless entry
sopranomobile
05-21-2004, 07:21 PM
Does anyone out there have instructions for programming a 1995 roadmaster?
tman
05-21-2004, 10:07 PM
Next time you post a roadmaster question, put it in the roadmaster forum, not the century
tinglygravy
11-08-2004, 06:51 PM
This is the roadmaster forum isn't it?
tman
11-08-2004, 08:44 PM
It was in century, I kindly moved it to roadmaster, so it would be in the proper place :)
tinglygravy
11-08-2004, 09:39 PM
1. In the trunk, on the lesft side find a black plug that goes to nothing Its just hanging there. you will se a white stripe on the black wires coming off of it.
2. just stick a small screw driver into the plug making sure that it touches the two small pins inside the plug.
3. holding th screwdriver in the plug you will hear the door locks and/ or trunk lock click.
4. do not remove the screwdriver and when you hear the clicks press one of the buttons on your remote sweetch and you will hear a lock click that means you just activated teh remote....
5. if you have 2 remotes press a button on the 2nd remote switch at this time and you will hear a lcok click meaning that remote will now work too.
6. remove screwdriver and test your remote switches.
