EASY fix for Loss of radio...P locks etc Mystery solved
daveyates
05-20-2004, 05:53 PM
Hi There..I had posted a problem on my G Caravan 98... loss of Radio..p locks.. accessory power, no horn without key in RUN.. BlahBlah...It seems the majority of the relays use a signal that is in SERIES with a bunch of different relays!... if one has no continuity the bunch of wires get no Juice.. Funny i was on my way home and I didnt realize I had not pushed the big relay on the junction block under the dash in all the way!..Cuz now my Signals werent working!.. when I pushed it in..My radio came on!!!!! then went off again.. attempts to make it happen failed until I took the relay out and had a closer look!..(those of us in canada have daylight running lights, a part of this relay!.) After taking the plastic cover off..and a close inspection with an Eye Loup Low and behold I found one of the contacts fro the spades to the board had a bad solder joint!!... after reflowing it and adding some more solder to make it permanant..NO MORE PROBLEMS.... If you mysteriously lose your radio.. p locks or stuff like this .. check this relay!!...
Im a happy camper....
Cheers all!...
Cheers all!...
