1990 Chevy Camaro I-roc overheating!!
ozzfan
05-19-2004, 09:07 AM
Where is my water going? And why? Maybe thermostat?? Tired of smoking while sitting at a red light! Sweet Car! :disappoin!! :banghead: ! Please help!
musclecarfanatic
05-19-2004, 04:41 PM
are you refilling your coolant all the time? if so you probably have a break in a hose or you might not have the correct mixture. give more information like how fast is it leaking.
from_chevys2nissan
05-20-2004, 09:18 PM
did you say you where smoking what color is the smoke and do it only smoke at the red light
if its just the lake that bothering you it might be the water pump the start to leak when there going bad.
if you are adding just water to your system then your wather is avaperation.
another thing you could try is stop leek i wouldn't i allways go stright to the problem and fix it
