headlight fog/mist problem?
ramo5150
01-17-2002, 08:32 PM
Need some help everyone.
I have some aftermarket Ion/Blue Headlights that have started to fog/mist up inside the housing due to the cold weather. Does anyone know what I can do to resolve this problem or have a web site that might help?
Thanx for the help everyone.
Great site....:cool:
drift
01-17-2002, 08:36 PM
reseal the lenses. there's a leak causing moisture to build up within.
GhettoLegs
01-18-2002, 02:20 AM
Is it a headlight housing that you installed, or just bulbs? If it's the housing, then yes... the seals are bad. But, it could also be that the bulbs aren't put in correctly or completely. If there's gaps where moisture can get in... you need to do something about the gaps. Avoid taping gaps near the bulb as the bulb gets very hot.
ramo5150
01-19-2002, 04:24 PM
Thanx guys,
But now I need to know how to reseal the housing of headlamps or the bulbs?
GhettoLegs: I installed all new housing and used the stock bulbs. So how or what do i use to seal the buld into the new housing. What i can't understand is that only one of the headlight fogs up.
If anyone else has any other ideas, i'd appreciate it.
