Civic Problems ECU
AK civic 91
05-17-2004, 11:42 PM
I bought a 91 Honda Civic 1.5 Liter with a manual. I was driving around and the electrical stuff (lights, radio, and clock) shut of. The rpm's said zero, but I was going 45 mph and the engine was turning over. As I slowed down it shut of and wouldn't start. It jumped started, then I brought it to the shop. The alternetor was checked out and it was fine, the battery and terminals were all replaced. Somebody said it might be the ECU, but I'm not sure what it is?
91CRXHF
05-17-2004, 11:45 PM
i would say check the alt. again same thing happened to me with my alt.
AK civic 91
05-17-2004, 11:46 PM
what about the rpm reading?
oldschoolcivic
05-17-2004, 11:48 PM
What you can do is test it with a know good ecu. If that doesn't work then you know it isn't the ecu.
AK civic 91
05-17-2004, 11:51 PM
my car sometimes doesn't start, but sfter a while it does. Somebody told me it might be because my starter has to cool down. Could it be something bigger.
91CRXHF
05-18-2004, 01:28 AM
ok to find out if your battery is bad or your alt. is bad start the car and while it is running take the positive post off the battery if it dies then its the alternator if it still runs then the alternator is still good
KoRnSaQ
05-18-2004, 01:35 AM
my car sometimes doesn't start, but sfter a while it does. .
Sounds like it might be the Main Relay
turtlecrxsi
05-18-2004, 12:00 PM
B/f replacing an ECU or alternator, do the battery test (remove positive connection). Be sure to check every wire connection to the main harness and every ground. One short could cause a lot of problems. Oh yeah, gotta make sure valve cover ground is tight or car won't start...
Bxcivic2000
05-18-2004, 07:56 PM
You might want to check your main relay, sometimes its that and not the ecu. These problems can cost alot of money, Good luck and let us know what happends
Bxcivic2000
FourthGenHatch
05-18-2004, 09:05 PM
When Main Relays get really bad I heard they will turn the car off when driving. Usually its just it won't start. I guess yours took a shit on you.
