lifting my 89 4runner
RandomYoshi
05-17-2004, 01:11 PM
just wanting opinions on easiest way to lift front and back of my 4runner. leaf springs in the back so i was thinking of spacers. all i want is 1 - 3 inches. in the front i have shocks so i was wondering if i can get get spacers for the top of the shock where its bolted down. would that work or would it mess stuff up?
C-DUBYA
05-21-2004, 12:10 PM
huh? what kind of lift do you want to put in? you need to crank the torsion bars in the front and a body lift will be your cheapest lift, if you chuck some bigger tires on. Also do a little more research on lifts before you go ahead, there are some garbage ones out there. Making your shocks longer will not do anything for lift. you'll regret a cheap lift if you don't know what you are doing.
