wont start
jgoertz7
05-17-2004, 11:56 AM
i have a jdm d15b vtec in my 88 crx si. i swapped the intakes and the distributors. i hooked up all the wires and tried to start the engine......NOTHING!!! all the interior and exterior lights work, but the starter doesnt click or even attempt to crank. what did i do wrong? the starter worked on the original motor so i know it is fine.
SiZ
05-17-2004, 12:03 PM
Look at how close the positive terminal is to the new intake you just put on.. If its really close, then put some rubber around the terminal, or wrap the intake in something that electricity can't conduct through.
If nothings working at all, its probably your battery.
crxlvr
05-17-2004, 07:50 PM
while your in there make sure you hooked up the starter correctly and havent blown the fuse in the process, double check your grounds aswell.
