radio wiring
Adam_29k
05-15-2004, 03:16 PM
Does anyone have the wiring diagram for the stereo
I also need the one for a PN 09394342 stereo that fits a 2000 or 2001 sunfire or montana
fluffybunny
05-16-2004, 12:36 PM
2000 sunfire radio wiring harness (http://gim.li:9001/servlets/BlobShtml?ShtmlFile=562222)
does this help?
does this help?
fluffybunny
05-16-2004, 12:37 PM
what year grand am?
Adam_29k
05-16-2004, 12:44 PM
oops, 97 Grand Am
Just one wire on the plug I can't figure out. Brown one, I know the speakers, power, ground, ignition, dimmer, one left over and it doesn't have a power antenna.
your link isn't working btw
fluffybunny
05-16-2004, 04:54 PM
oh, its sunday i dont think they work on off work hours........ hmm well i cant even get into the homepage right now.ill get back tommorrow lest someone has a diagram
Adam_29k
05-16-2004, 06:10 PM
I managed to figure out what was what and then found out the radio I was sold still won't fit :(
quenncy
08-05-2006, 03:17 PM
Changed my Delco (pn 09394342) from one chev to another and now it is locked up. Does anyone know the unlock code or how to receive it? Thanks so much, Quenncy
tommy00gt1
08-05-2006, 05:07 PM
I'm afraid you're stuck with a boat anchor. The only person who knows that unlock code is the person who enabled and set the code. Your radio is locked.... that is the purpose of Theftlock.....making the radio useless for anyone to use without knowing the proper code.
The Theftlock is a anti-theft measure, meaning that the radio will be useless to thieves. The thief would have to know the correct code, or be stuck with an inoperable radio.
Unfortunately, this poses a problem for a rightful owner if they forget or don't know the code. The radio is useless to the owner too. So in short, you're stuck without knowing that code.
xeroinfinity
08-06-2006, 10:44 AM
Damn, this is an old ass thread,
should hav made a new post quenncy !
But what years your car?
SOme radios can unlocked, not sure how,
but its on here at AF somewheres.
quenncy
08-06-2006, 02:13 PM
Got any clues as to where to look my friend? thanks
xeroinfinity
08-06-2006, 03:23 PM
From what car and year,
to what C/Y are you swapping>?
Do a search in the GA forum for radio locked...
heres the results (http://www.automotiveforums.com/vbulletin/search.php?searchid=1625692), should find what you need there.
Hope that helps
Hope that helps
ajstine
05-18-2009, 03:57 PM
I've got the same problem Quenncy...did you find any solution?
Anyone find out how to unlock a Delco radio in a 2000 Pontiac Sunfire (p/n: 09394342)?
xeroinfinity
05-18-2009, 05:25 PM
Welcome to AF ajstine !!
kinda in the wrong Pontiac section, but I think I can help you.
If the theft deterent was activated, and your batter went dead or was disconnected, you might not be able to unlock it with out the lock/unlock code.
You can try simple default codes, 000(0) or 1234, could be a combination of 3 or 4 numbers.
Good Luck!
Good Luck!
