door seals on 89 suburban
deester
05-13-2004, 04:31 PM
can anyone tell me how to remove the rubber seals on the front and rear doors of my sub. also how are they to be re-attachrd? thanks.
Ingoldx1
05-13-2004, 08:26 PM
If you are refering to the front and rear side doors, you should remove the trim around the doors first. Then start on the bottom joint and pull it off. I have the same year sub, I purchased my replacements from JC whitney. The rear cargo doors have clips and are even easier. Just pull them out and replace them the same way. The new seals can be tricky to figure out which corner goes where, so don't rush it. Check out LMCtruck.com and get one of there catalogs, they can be more expensive, but they also have stuff that is very hard to find + the catalogs are free!
- Ingoldx1 :smile:
