update
zdude
05-13-2004, 05:26 PM
vsiev, i got the locks and lifts. the lifts went in just perfect, and they work like a dream. i havent done the locks yet, i figured to wait till i get done with the other two projects first to work on that since its the biggest.
thanks vsiev for your parts
i got the headlight bracket from aricanderson, and it went in and everything, fits perfect, but when i plug the new one in, it goes up, and the other stays down. then when i flip the switch to make them go up, the new one goes down and the other one flips up. so they are opposite each other no matter what i do. i tried plugging the new one in when they are up and down, i tried adjusting the height knob and the rod that connects the motor to the bracket. but no matter what i try, they are always opposite. if anyone has put a new headlight in or done anything like this and has had the same problem, or knows how to fix it, let me know. all help is appreciated.
thanks
paul
zdude
05-13-2004, 06:40 PM
come on guys, im not gonna drive around with one headlight up and the other down, and ill probably get pulled over when i drive at night...i need a little help here
vsiev
make sure the wiring isn't cut or rewired...might be a miss wiring...you can try the arm again....you know take off the arm from the motor, have the lights up then reattaching the arms the same as the other side. do you still get the rattle in the back from the hatch? Oh and the locks, you can take the barrel off of them and swap them with yours so you can use your existing handles. Or just install the red ones and repaint later lol
vsiev
05-13-2004, 06:41 PM
oh and you can just remove the arm from the motor and never drive at night lol
zdude
05-13-2004, 06:44 PM
lol, thanks vsiev, you always seem to be able to help me. i havent gotten the locks in yet, ive been workig on the lifts and headlight since 3:30. hopefully removing the arm and letting them both down, then reattaching it will work, sorry i got a little antsy with that last post, i just wanna get this done tonight so im not messing with it before and after work tomorrow
vsiev
05-13-2004, 06:55 PM
no prob....i hate working under a time limit....it sucks ass. I remember doing my conversion and couldnt' get it done cause of the wiring(which was a B*tch) and I had to go to work. So i had to borrow a car and i got it done the next day. Good luck with it...let us know how it turns out
zdude
05-13-2004, 07:08 PM
damn vsiev, your a genious, the idea you gave me worked perfectly!!
vsiev
05-13-2004, 07:25 PM
another job complete. that is good to know. What else you got to do?
zdude
05-13-2004, 10:24 PM
well, lets see, i just got back inside from my projects. all done for now, i got the trunk lock in, both door locks, headlight bracket, kill switch for my sub-(dont worry its nothin special, just some bass for my car) and i think thats about it. im so happy i got it all done tonight even though the red handles look pretty sketchy, ill probably paint em sometime this weekend. thanks vsiev for all your help and supplying me with the parts, also thanks to aricanderson for the headlight bracket even though it took a week and a half.
the list of stuff that i still have/want to do is endless
vsiev
05-13-2004, 11:22 PM
well you know you can take the lock barrel out and swap it so you can use the existing white handles. Nothing complicated i think, just have to remove a spring coil holding the barrel and then swap it, and replace the spring coil. Oh and sorry it took me a while to ship it out to ya. At least now people can't get into the car lol
kingcarm
05-14-2004, 08:45 PM
Hahahahahaha.
zdude
05-14-2004, 09:50 PM
i had a key made, and the new one is all f***** up, its like at least a millimeter short, and it has to be right on, i hsave to pull it out a little bit to get it to work. its a pain, but its a spare, if i have to use it, i can. again, vsiev, thanks for everything, and dont worry about the shipping, at least it got here
vsiev
05-14-2004, 09:59 PM
well when i get the ignition off, i will send you the other key...i bet you got the key from home depot they suck a$$ lol....
zdude
05-15-2004, 01:25 AM
nope, ace hardware...
