won't start
hank64
05-11-2004, 08:02 PM
ok i im exausted,still no start new coil ,new rotor,new cap car turns over no start jumpered dme don,t hear fuel injectors power up,do hear when i atatch a 9v bayttery,getting positive to injector tested with meter positive to ground 12v when dme is jumpered should i be getting a power reading rite from the injector itself when i jumper dme,or start? getting fuel up to the rail for sure getting spark too what can i try?
83-944
05-12-2004, 05:20 AM
You should get about 10 volts from the injectors when they're plugged in, injector windings take 2 volts to power.
Get a Bosch noid light. Some major auto parts store carry them. That will for sure tell you if the injectors are firing.
http://www.drivewerks.com/catalog/ShopCart/TOOL/POR_TOOL_CAT447_pg28.htm - for reference
Are the plugs wet?
