Shaking, Engine's Rattling
2k1EclpseGS
05-11-2004, 12:44 PM
My car just started shaking when i stop or when I'm doing city driving. My engine light's on and I want an opinion before I pay more than I really hafta. I popped my hood to see if everything was normal, and the engine's shaking. Could it be a bracket?
Also, there's been some hesitation for some time but it comes and goes and never produced a problem. I had a transmition flush and that was supposed to stop the hesitation but, obviously, never did. Any ideas on what's going on? Thanx!
00_GS
05-11-2004, 06:29 PM
Have you had your car tuned up recently? The wires and plugs may need to be changed. That could be a problem with the hesitation. The motor shaking could be a motor mount. It may be starting to warp or crack. Get that checked out!
01spyder[GT]
05-11-2004, 08:49 PM
Agreed. Motor mount is my 1st guess (not a mechanic though). I would go REAL easy on the accelaration while driving it (hopefully straight to the mechanic.) I imagine that IF it isn't under warranty then you are looking at $$$. Removing the engine is always expensive...i'm told.
I would think that if you have any mods you want done to the car (and have some more $ if no warranty) then now is the time. Less labor charges/time.
BlueGT00
05-11-2004, 09:34 PM
mY guess would be a busted engine mount also.
2k1EclpseGS
05-12-2004, 02:02 PM
Ok, I went for a diagnostic test and turns out I needed new spark plugs.... tune-up while I was there, too. So there's the solution. The hesitation I've had all this time was because my spark plugs were bad.
01spyder[GT]
05-12-2004, 02:57 PM
so the plugs did the trick? have you driven it yet?
