Fuel Gauge
mikelebo99
05-11-2004, 09:56 AM
Hey everyone. Been awhile since I have needed to post anything but as with all cars its not a matter of if, but when!!
I had my AC system checked to verify that my compressor was bad. As I feared I need a new compressor. However, the reason for my posting has to do with my fuel gauge. I have looked thru all the postings and do not see any additional info on fuel gauges. The only one I did see referred to the same problem I am having, which is a fuel gauge that goes from Full to Empty and back again.
Does anyone know if this could be related to a simple check on my A/C.
Thanks
dred98
05-11-2004, 11:03 AM
Mine did that for a few days last December - I filled it up and it was on empty after about five minutes drive, and it bounced around for a couple of days but then straightened itself out. :screwy:
It's been OK since - so wait for a while, maybe it will go away on it's own. :)
RobertHammen
05-11-2004, 02:38 PM
This is usually the sending unit flaking out. Probably not related to your AC compressor. I had the same experience as dred98 back in December - at a fill it went all the way up, then all of the way down. As I watched it it went all of the way back up, and it's been fine since.
mikelebo99
05-20-2004, 03:22 PM
My gauge has been fine the last couple of days. Really makes you wonder though.
old goat
05-20-2004, 05:51 PM
My 97 does a similar thing. It will intermittantly read high, but only after the ignition has been on for a few minutes. I read on another board (that's now defunct) that it could be caused by a high resistance connection at the fuel sender. The post said there is axcess in the trunk under the mat. I haven't had time to try it yet. We use the fuel used on the display.
waynem451
05-21-2004, 12:33 PM
My gas guage does this everytime I top it off. That little bit of extra gas that I try to add seems to make it stick or something. Anyway, all i do now is just put in as much gas as it will take until the hose automatically shuts off and the guage seems to work fine.
Wayne
mikelebo99
05-24-2004, 10:02 AM
I noticed that after I filled up the other night that my guage started acting up again. Once I drove 20-30 miles it stopped again.
dsutter
06-24-2004, 06:13 AM
My 2001 4.0 L V8 had the same fuel gage problem. It ended up being the fuel sending unit. Big money $350. I was not happy about it. The problem is gone now.
