Choicess
metal240
05-10-2004, 03:47 PM
Well, im of course thinking of swaping my engine in my 90' 240sx. I honestly have little to no knowledge of cars etc.. just know a few things..
Anywho, i went to www.heavythrottle.com i think it is, and saw they sell engines etc...
To the question, should i buy their $4700 kit or just the engine and my own parts?
This is the kit: http://srswap.com/shopexd.asp?id=749
Is the kit worth it? Or will i end up having to buy most of it.. for example the pipe-ing for the turbo?
I know i want a boost control, along side with a new intake (maybe injen's intake?) And then slowly upgrade the engine peice by peice.
SHO411
05-10-2004, 08:05 PM
I say for for $4700, slap on an LT1 and you will never have to worry about boost again LOL :naughty:
But it seems kind of pricey just for parts, not including labor, got a shop down here in ATL that said they could get me an SR20DET and install it too for between $2200- $4000. they had an RB25 240 that they say they charged the guy $4400. the car was tight except he had blown his turbo and was getting a new one put in.
R.W.240
05-10-2004, 08:26 PM
SR20DET Clip = 2500+$ at Neilshinmotors (sites down)
HKS Mild Downpipe=190$
Exedy Clutch =400$
Greddy Profec B = 350$
Apex Power Filter = 115$
the reason HTs package is so expensive is that they have a ton of other stuff thats not really nessicary if you have a full clip. Like Gauges, Intercooler (V-SPL), Fans, Radiator. if you only have a motor set most of it will end up being nessicary ( or atleast make it less of a pain in the ass)
a member on this board claims to be able to put a RB26 with the twins in for 7500 including IC.
Exedy Clutch =400$
metal240
05-10-2004, 10:15 PM
I'm stuck on a rock what to do lol. Basically, i dont want to end up spending 8g's on a freaking engine swap. Nor do i want to give my car to some1 who's never swapped a sr.. into a 240sx.. The kit looks tempting in it's own way, but 4700g's plus their 1600 install is a little more than im willing to dish in right now. 6300 in total if i do it their way all the way. Sounds over priced. Way over priced.
stealthj
05-10-2004, 10:33 PM
1,000$ ca18det+ 1,000$ swap + 1,000 240 w/ blown headgasket+free boost controller= 200hp turbo 240 for 3k
fuck the sr
fuck the sr
metal240
05-11-2004, 09:01 AM
This is my first time hearing about the CA.. from the name, sounds like a lesser grade of engine, but what do i know? So what is the CA18 from? What car i mean.
Well just checked it out, it's basically 15hp over what i got now.. And then needs a turbo for that. I still like the sr20det, not bad. I also like the 300zx's twin turbo, but too many cuts for that.
Is it true i'll have to go find parts to make the sr20det work? Due to the fact my A/C wont work and steering fluid reservoir has to be moved which needs parts too?
So i'm guessing im completly better off with a clip? and then just replace the parts peice by peice with newer ones?
240/350Z
05-11-2004, 12:34 PM
a front clip is the best way to go IMHO. but you urself are going to end up paying more than some people because you are going to have to buy from a shop instead of having a connection. My friend and I are swapping in a 300zxTT into his N/A Z and the front clip has everything we need, even though it is good to replace old parts before install.
nissanfanatic
05-11-2004, 02:42 PM
everything you need to know about the sr swap.
stealthj
05-11-2004, 03:47 PM
your block is made up of a couple soda cans
metal240
05-11-2004, 09:28 PM
lol all pepsi cans baby. I guess i'll go for a clip thing, thanks for the help. Time to go hunt for some el-cheapo clips.
zdude
05-11-2004, 10:43 PM
the ca is a 1.8 liter turbo dual overhead cam engine. you can get that just from then engine code
ca18det
CA- series of engine
18- equal to 1.8 liters
d-dual over head cam
e-electronic ignition
t-turbo
ka24e
ka-engine series
24-2.4 liters
e-electronic igntion
rb26det(t?)
rb-series
26-2.6 liters
d- dohc
t(t?) twin or single turbo, not quite sure which
anywho, my lesson of the day is done, good night
ca18det
t-turbo
ka24e
ka-engine series
24-2.4 liters
rb26det(t?)
rb-series
26-2.6 liters
d- dohc
stealthj
05-12-2004, 04:23 PM
e=fuel injected
zdude
05-12-2004, 09:00 PM
thats right, i knew it was either that or elec. ign, but ign, made more sense cuz of the e in electronic.
