99 ford ranger
DWB403
05-08-2004, 05:42 PM
engine turns over, will not start. check spark ok. next is fuel. have no owners manual for relays and store bought books are not to this model of fuse and relays box. does anyone know about fuel relay,etc and what steps to take. Please help, thanks
splashiod
05-09-2004, 10:12 AM
When you 1st turn the key on you should be able to hear the fuel pump for about 5-7 seconds? There is also an inertia switch that is supposed to cut off fuel pump incase of an accident. I'm not sure about a 99 because mine is a 95 so I can't help much on relays or location. Did it just not start one morning or did something special happen? You can pull fuel line off just before filter (under truck on drivers side door frame on mine) to see if pump is working. Good Luck!
2000mudder
05-11-2004, 11:15 PM
could be anything. need more info. was it running before? what motor? if you have spark it sounds likely to be in the fuel department.
TheRangerOfDanger
05-13-2004, 08:12 AM
you may want to check the fuel injectors - they may be clogged up or partially plugged
chaser29
05-17-2004, 09:52 AM
http://members.cardomain.com/12311974
When is the last time you changed your fuel filter?
Check your air filter INTAKE as well. Both of these would cause your problem.
This site should help.
http://www.therangerstation.com/forums/index.php
rangerdave
08-16-2004, 10:58 PM
i have a 99 ranger xtd. cab and was wondering if there were any tips or tricks to gain any hp. anything will help. thanks dave.
TheRangerOfDanger
08-23-2004, 04:16 PM
There's so much to do it's not even funny.
for starters, go with a nice intake (ie a cold air like mac performance or K&N FIPK or a K&N replacement filter), than go for a nice exhaust (Flowmaster, magnaflow, dynomax, or glass pack), ignition system (Holley, MSD), Throttle body spacer (http://ranger.racenet.net), port and polish, internals (Morana Racing), and if you got mucho dinero, you can retro fit a whipple supercharger for a 2002 ranger and get it chiped from the RIGHT PEOPLE (ie superchip.com) . There's lots in between, just check out summitracing.com, and pick up one of their catalouges.
rangerdave
08-23-2004, 11:47 PM
i know about all of the after market things but i was wondering if there was anything to do to the engine w/o buying anything or putting anything on.
TheRangerOfDanger
08-24-2004, 08:28 PM
in that case, the only thing i've heard of without spending any money is to advance the timing 3-6 degrees. I've heard it does help the top end out alot...
