Electrical Problems
JoeZamp
05-07-2004, 11:44 PM
I have a 1988 Fiero 4 cylinder.
Two weeks ago my Fiero shut down on a return trip.
The car shut down with NO warning. Just went dead.
Had it towed to a garage. The mechanic put on a new serpentine belt.
It ran fine for the next two weeks.
Returning home a few nights ago, the headlights and dashboard lights started flashing in a very erratic manner. Every time I would accelerate, it got worse. The car surged very badly. Luckily, I was able to get the car home, then it died in the driveway. It will not turn over and is COMPLETELY dead.
Has anyone had a similar experience? I was thinking it may be the ignition module.
Any help is appreciated.
Thanks....
JoeZamp
Thanks....
JoeZamp
86FieroGT
05-08-2004, 12:24 AM
I've had an ignition coil go bad on my GT. It would die once the engine compartment got hot enough, and it wouldn't start until it had cooled down. I got home by stopping to pour water on it every couple of miles. The damned thing is right directly on top of the exhaust crossover!
Anyway, after it died it would turn over. It just wouldn't start because there was no spark until it would cool down. Is this anything like your problem? Does it start back up once it cools down some?
JoeZamp
05-08-2004, 01:03 AM
86FieroGT
Thank you. It will not start at all, even the next day. I am baffled, even my mechanic buddies are baffled. THANK YOU FOR THE SPEEDY REPLY!
I'll try and let you know what I find and THANKS AGAIN!!!!!!!!! I will update you on anything else I find. Is your Fiero running again? I hope so!!
JoeZamp
JoeZamp
RedFiero
05-09-2004, 12:58 PM
Check the charging system. If the lights surge or go dim that is a good indication of charging problems. Maybe it's putting to much out and cooking the battery.
JoeZamp
05-09-2004, 10:01 PM
RedFiero and all others who posted.
I have found the problem.
Too easy, bad battery terminal...
Was not showing, traced it...now fixed.
Everything is great.
Thanks to all again.
JoeZamp
JoeZamp
RedFiero
05-09-2004, 10:07 PM
Good going Joe. Be sure and use some kind of protective coating on the new terminals.
JoeZamp
05-09-2004, 10:56 PM
RedFiero....
Got it covered and thanks again.
I will be posting a pic soon of my Fiero online so you can take a look. It is in really great condition.
Would love for you to see it.
If you have a pic, would love to see yours.
My Fiero is red also!
THANKS AGAIN....THIS FORUM IS FANTASTIC.
What nice people! Love it.
Later
JoeZamp
Later
JoeZamp
TH3 F13R1AN
07-30-2005, 09:44 AM
hey i have an 86 GT. ive been having some problems with getting it to start, sometimes it does, other times it doesnt, whenever it feels like it. i am getting fuel, enough too, and i just put in new plugs and used a multimeter and tested a new pick up coil i put in, as well as the ignition coil. does anyone have ANY ideas? HELP. thanks
-Will-
-Will-
mruwka
07-31-2005, 09:08 PM
-Will-
85 GT
there has to be some thing missing when it dose not start.....the trick is catchinig it when its not starting....intermitint stuff means loose wires..or opens or shorts.... wiggal the wires while starting or running the car.... see what happens..
heres a TSB for our car...the only one that i found that would fit your discription...
:cool: :cool: :cool: :cool: :cool: :cool: :cool:
Engine - No Start/No Run
Notes
Number 86-8-5 Date 11/85
Subject: ENGINE WIRE HARNESS TO EXHAUST PIPE CONTACT ON V6 ENGINES
1986 FIERO
"Please disregard previous bulletin 86-3-2, due to a wrong section number and change to 86-8-5."
CONDITION:
Certain 1986 V-6 equipped Fieros may experience a no-start no run condition or may hesitate due to shorting of the HVAC and fuel pump relay wiring harness against the exhaust manifold.
CAUSE:
The condition is caused by the above wiring harness being routed too close to the exhaust manifold or pipe.
Figure 1 - Wire Harness Location
CORRECTION (See Illustration):
Reposition the wire harness, after any necessary repairs, behind the crankcase ventilation tubular cross pipe (closer to the rear bulkhead) and away from the exhaust pipe area and secure the harness with a tie strap. Vehicles after VIN FP201000 will not have this condition.Labor Op: N6420
Labor Time: 0.5 hr.
2-REAR BULKHEAD
2-EVAP FRESH AIR TUBE
3-AIR CLEANER ASM
4-ENGINE ASM
-Will-
85 GT
Notes
1986 FIERO
CONDITION:
CAUSE:
Labor Time: 0.5 hr.
2-REAR BULKHEAD
3-AIR CLEANER ASM
4-ENGINE ASM
