mysterious starting problem
wickedplastikman
04-30-2004, 04:59 PM
my girlfriend has a 2000 accord v6 and recently there has been a srange problem. the car won't start when it is really humid or raining. i had an old camry that had the same problem and i found out that it was the ignition coil. but the accord has a dis ignition system so i have no idea what to look for.
has anyone had any similar problems or suggestions on where to look?
wickedplastikman
05-03-2004, 02:23 AM
nobody has a clue?
grimple1
05-03-2004, 03:12 AM
by all the mods on your car, i'm guessing you checked the positive battery cable?
my wifes intrepid had the same problem with her car and i changed everything.... plugs, wires, battery, etc.. and finally (after a co-worker mentioned he had the same problem) changed the positive battery cable and it fixed it. never had any problems with it after that.
good luck.
jakedubb
05-04-2004, 11:00 AM
I would check battery cables,grounds (eng. & chassis) and starter connection first. I've also heard a bit about the main relay causing this symptom. Do a search and see if you come up w/ anything. I just don't remember where I saw it or I'd lead the way! Hope it helps.
wickedplastikman
05-04-2004, 02:15 PM
thanks i am still working on it. i changed all the plugs because they looked pretty bad and made sure the battery connections were tight and clean. lets see what happens.
