2 Amps
sammuts
04-30-2004, 12:56 AM
Hi,
This might be a dump question but if I m going to connect 2 Amps on the back of my car do I need to pass 2 power wires and have 2 fuse boxes or I can use one of each and then split them at the back
skubydobdo
04-30-2004, 08:33 AM
yep, you only have to run one fuse up front (close to the battery (pretects your car) and a split it in the back using a block. (1in 2 out, or 1 in 4 out, whatever) You can even run the ground wires for the two amps into another block to give you one line to ground instead of two.
