88 CRX Si B16 or B18 everyday driver
NITROtooFUN
04-29-2004, 01:28 AM
I finally moved to Cali and after seeing a CRX with a ZC i am hooked.
Im gonna be driving this car everyday but i want to be able to compete with some, if possible mustang gts, cause i hate thiose things. Should I gor for the 16 or 18. Is the 18 alot heavier than the 16. I want to be able to take tight turns without alot of understeer. Im not gonna do any force induction but i plan on fixing up the engine. Im really leaning towards the 16 but if yall have other recommedations do tell or if there is a good link to help explain this please give.
thanks
thanks
NITROtooFUN
04-29-2004, 01:35 AM
I have a $5000 budget
joebowlr21
04-29-2004, 01:48 AM
5k.........you can build a pretty fast car for that.
First, look for an 88 crx HF (that is the lightest model)
Swap in a B16a w/lsd tranny(JDM spec perfered)
That will run you about 3k there.
Start Tuning with Skunk2 TB or Integra Type R TB and Intake Manifold.
Go with JDM 4-1 header from Integra R
SKunk2 cams would be good along with titanium valves,springs, & retainer.
If you still have money left over from all that good stuff, i would fine tune with Hondata and buy some good street tires.Of course that is not a full build, i mean you could still add pistons,rings,rods, etc. But that is what i would start with. Plus if you strip the CRX i'm pretty sure you can run low 14's/high 13's if you know how to get a good r/t at the track. That will have you competing with Cobra's if thats okay with you.
NITROtooFUN
04-29-2004, 03:47 AM
Well I already have a CRX Si so i dont need the HF. This is prob what i be ordering http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30003 or should I go for http://www.hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30002 Does it have everything I need?
Im sorry im a newb but what is a skunk2 TB
And do yall know about how much will a shop do a swap for and how long it usually takes?
SiZ
04-29-2004, 07:13 AM
I'm not getting more than one post into this thread. :p
B16A.
B16A.
NITROtooFUN
04-29-2004, 02:38 PM
So I should just go for the engine with 170 hp? Their both the same size right?
KoRnSaQ
04-29-2004, 04:02 PM
either way you go, you need to remember you will have to get mounts, axles, and the hub assembly or knuckles or whatever you call them cause the axles you get have a diff. spline count then your stock ones
crx91
04-29-2004, 09:41 PM
yes their the same size.do you have the rex already?
Cjz89civic
04-29-2004, 10:17 PM
There is a probllem with a JDM motor it will not smog in cailifornia. Or for that in the US
shaddr3
04-30-2004, 12:15 AM
What will get you, emmissions? Ahhh over here in Maryland, we dont have problems with that. I call up my buddy, give him $50 and im passed even if I dont have a door on the car :D.
NITROtooFUN
04-30-2004, 02:49 PM
i already have the rex. So the motors i posted up are not usdm which mean i wont pass the smog test? Can you tell me where i can find a usdm and how i can tell it is one?
NITROtooFUN
05-01-2004, 04:07 AM
who knows where i can find a B16 that will past smog test in california?
shaddr3
05-01-2004, 02:05 PM
just find a UDM b16a1. the b16a is a JDM engine.
civicHBsi91
05-01-2004, 07:37 PM
5,000?....go b18c!!
NITROtooFUN
05-03-2004, 04:49 AM
Well is the B16a1 a light lighter engine than the b18c?
SiZ
05-03-2004, 07:07 AM
Barley, if at all.
If you've got the $, then the GSR would be the way to go. With the HAsport hydro-cable mounts and an ITR tranny. :D
