Ecu ?
nismounlmtd
04-28-2004, 04:51 PM
My friend has a 2002 wrx. He has intake and full catback exhaust and manual boost cont. He just got this thing that plugs in and redoes the ecu. he says it goes fine up to 2500rpm and then after that its like hitting a brick wall. any reasons y? bad a/f mix maybe?
LjasonL
04-28-2004, 05:22 PM
Well, we'd have to know more about it before we could give a decent answer
My 1st thought would be to unplug it :lol:
dlinvill
05-09-2004, 12:15 AM
Sounds like he didn't get the right a/f map uploaded to his ecu. I'd have him take it off and either send it to a tuner for a reflash or redo it himself depending on the part. On some aftermarket ecus you shouldn't use a boost controller because of the way the ecu is faking the readings.
ragnarok720
05-09-2004, 06:34 AM
Just buy a UTEC from TurboXS or ECU from Vishnu or Cobb Tuning.
DrBiggly
05-12-2004, 11:09 PM
What product did he get? It sounds like any time he's in closed loop fueling that something isn't right. At WOT does it still act the same?
Also it could be that the ECU add-on is killing boost. It's preventing it from building boost somehow, although there is no way that's an intentional design.
If he has a Unichip, tell him to get rid of it. Those things can be dangerous; they're almost never tuned right and bypass the stock ECU's control over timing. If he has a Unichip on his car and it's pushing timing and the ECU hears knock, the Unichip will prevent it from pulling timing like it's supposed to.
scottb2004
05-13-2004, 03:09 PM
tell him to get the Cobb AccessPort, that thing is awesome.
cche2052
06-17-2004, 06:55 AM
What's that?
freakray
06-17-2004, 07:12 AM
What's that?
An ECU.
