Setting Valves on 89 GMC
bubbabryan
04-28-2004, 12:10 PM
Give me some tips on setting the valves on 89 GMC 2500 with 5.7 350. I used to set them by loosening off the rocker nut until I heard them "slap" and tightened them back until it quit adding 1 round. Now my hearing has left me and I need another way to set the valves since I can no longer hear like I used to. Also...If you know of a torque spec that will apply to the rocker arm nut let me know.
seashift
07-15-2004, 11:13 AM
with the valve closed, turn the pushrod with your fingers as you tighten the rocker arm, when the pushrod stops turning freely by finger, add 1 round.
